I downloaded and installed the hybrid.dmg image in following the instructions in Install.
I’ve now moved on to First Steps: Adding Object and Marker. It seems that I can’t access arduino.local:8080/ as I get a page error. I can access arduino.local but it’s the standard Arduino Yun configuration page I believe.
Any idea why I can’t access the developer interface page through arduino.local:8080?
@sylvain I had this same problem , check your router/modem configuration page to see if wireless isolation is enabled
if it is enabled ,then disable it , it prevents devices from communicating through your ports ( 8080 ,80) which are used for various functions
my problem was resolved after disabling wireless isolation on my router
