My reality editor crash in my ipad air with OS 10.0.2. It used to work fine but after I update the ipad and re-install the latest reality editor, the app will crash when I open it.
However, when I connect the ipad with a different wifi from the laptop, the reality editor can be open and no crash.
Which reason cause this issue? Can you help me with that? Thanks!!
@valentin Hi! Thanks for your update, and it worked on that day. But it does not work today again which always displaying “loading object” in Reality Editor. I dont know why and I created a new discussion topic for this.
@valentin, I have the same issue. The reality editor crashes on both my iPhone (iOS 10.1) and iPad (iOS 10.2) as soon as a server is running on the network.
In case it’s relevant: I’m running the Hybrid Object node.js server on a Raspberry Pi zero.
Thanks for the fast response! Already tried that, same result.
I was following the raspberry pi guide, but started to look around in the other guides as well. There, I saw that v0.12.9 was required for node.js, and that v4-v5 were not supported (I was running v6). Currently installing v0.12.9 and retrying, keep you posted.
