I’d like to install Open Hybrid on the raspberry Pi (as an Hybrid Object).
I understand that it’s not implemented yet for raspberry, I can try to do it.
==> If you had to do it, how would you start? What would be the main steps?
Can you confirm that software is realease under the “Mozilla Public License, version 2.0” license ?
You do not need to remove the ArduinoYun from object/hardwareInterfaces. You can define many hardware interfaces that are searched for at the same time.
Your first TODO should work out of the box.
Your second TODO might be more complicated and we could keep up a conversation about the APIs.
I think my advice would be that you study the arduinoYun hardware interface and come up with ideas how it could be easy adopted for the RasPi
This code https://github.com/openhybrid/object runs on your RasPi out of the box.
The problem is that you need to tell it how to connect to the GPIO or any other input output that you want to create.
https://github.com/openhybrid/object confirms also your question for the license.
You can see in every source code file the license under which it is released.
In our case it is mostly the mozilla license.
You will need to run linux on the Pi. Within linux you will need to install the node.js compiler. This allows you to run the open hybrid server.
Since you run Linux, the networking hardware is taken care by the operation system.
It does not matter if there is ethernet or a wifi dongle.
If the PI has a network connection, the open hybrid server will work.
hi
i went through the hardware interfaces code, my doubt is that is it possible to use the same code for the pi by redefining the code for connection alone
Done: I’m able to connect to the IOS app almost out of the box as you said. I still removed the arduinoYun interface because it needs librairies that didn’t work on first try on the raspberry.
Todo: document how to install node.js and the required librairies on raspberry: I have a hard time making all dependencies working well on raspberry: it has to work on the right ARM version. I’ll post all the steps to install node.js and its dependencies when i’m able to make it all works. Todo: Install a debugger: I understand the main steps of the workflow. It’s difficult to understand the details without a debugger, i’m trying to install one but it add more dependencies to make it work.
To sum up, it should go faster when I’m done with the install/compatibility issues.
@V_Mohammed_Ibrahim : using it on raspberry requires to rewrite some interfaces, that’s what i’m trying to do. Would you like to help?
Hi, the dependencies for the Hybrid Object won’t install.
I’m getting this error
/usr/local/bin/node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.20' not found (required by /usr/local/bin/node) /usr/local/bin/node: /lib/arm-linux-gnueabihf/libc.so.6: versionGLIBC_2.16’ not found (required by /usr/local/bin/node)
@professorminh I have confirmed that OpenHybrid will run on Raspbian GNU/Linux 8.0 (jessie), I have not tried an earlier OS version. It may run on 7.8, though. Before upgrading, could you try the following steps and let us know if they work well for you?
Update the system software.
sudo apt-get update
sudo apt-get upgrade -y
Remove the default nodejs instance and replace it with v0.12 or higher (more details on nodesource github)
@valentin yes we should specify that too it will be a good, i will check and tell the version of OS and node @professorminh if the error still remains after following @KevinOrtman instructions let us know ,we may need to test it on the OS you are using
