Hi all , welcome to the forum !
if you need any help about Openhybrid or find any bugs ,you can post it here in this thread
tag someone by using “@their _username” to get quicker response
I/O points not showing up on reality editor
continuing from here → New Reality Editor Version 1.5.7 - #13
@ivanlin try changing the name of your HybridObject to “slider” , the obj.add(“slider”, “led”); adds a I/O point named led to the object called slider so if your object has a different name then the I/O points wont be added ,
i think you have named your HybridObject differently ,
try creating a HybridObject with name as slider and try again
you can see here for some clarity → http://openhybrid.org/reference.html
Hi, @V_Mohammed_Ibrahim,
Do I need to align all the file name to ‘slider’? like, slider.jpg, slider.zip (downloaded from Vuforia), the database name of Vuforia and the target name in the database folder of Vuforia?
no , @ivanlin you only need to change the name of your HybridObect
what did you name your object when you used the “create new object” ?
i believe you have named your object as target so check is this works obj.add(“target”, “led”);
Hi, @V_Mohammed_Ibrahim, @valentin
Thank you both. It works!
I would like to try it on Raspberry Pi and other platforms afterward.
Hi,@V_Mohammed_Ibrahim I am a beginner,have read the introduction on websitehttp://www.openhybrid.org/desktop—laptop-computer.html.But I still don’t konw how to install Open Hybrid Server in my windows laptop.Cn you help me?
Hi , welcome to the forum
To get the server working in windows :
Install nodejs (32 bit or 64 bit)
Windows 32-bit Installer: https://nodejs.org/dist/v0.12.9/node-v0.12.9-x86.msi Windows 64-bit Installer: https://nodejs.org/dist/v0.12.9/x64/node-v0.12.9-x64.msi
confirm that your nodejs install is working
type “node -v” or “nodejs -v” in the terminal it should return the version on installed node
type "npm -v " next it should return the version of npm -
if the above steps went well , then go to Desktop & Laptop Computer and do steps 1 - 5 and it should work
Hope this helps , do ask if you need any help
Thank u!
I don’t know if the result is right,
And the next step:
Dont type the command inside node terminal , you are supposed to type it in a normal terminal ( cmd or commad prompt)
after installing nodejs
open command prompt and then use the command like this
helpful thank u!
